AnsweredAssumed Answered
Service Area Network Analyst Issues - ArcPro
Question asked by andersonv95 on Dec 11, 2017
Latest reply on May 14, 2019 by MMorang-esristaff
I am having an issue with generating my service area polygons. Everything works smoothly until I click "run".
Here is the process I have gone through:
- I have 15 facilities that I am trying to run the analysis for
- All are geocoded with a 100% match
- I selected Network Analysis, then Service Area
      -Network Data Source is set to esri.com (Default)
- "Make New Analysis Layer: <Service Area Layer>" runs and then finished
-Network Analyst tab and Service Area tab open
- "import facilities is selected"
   -Geoprocessing pane opens
      -Defaults for everything are taken
      -input locations: "my layer of 15 points"
       -"Run"
-Works perfect, locations are loaded.
-"Run Analysis"
-"Solve Analysis Layer: Service Area 1"
------->"Failed. "Error 030024: Solve returned a failure. Failed to execute (Solve)"
Any ideas on the issue or how to fix it? I have tried changing the cut offs, mode, direction, polygon settings, and changing all settings in parameters. I have plenty of credits, so that shouldn't be an issue either.
Thanks!
Victoria
Outcomes
