peterverst
Delete Empty feature from FGDB in Arcgis Pro
Discussion created by peterverst on Dec 9, 2017
Latest reply on Dec 10, 2017 by bixb0012
Good Day,
One of the scripts i use is:
  1. import arcpy
  2. from arcpy import env
  3.
  4. env.workspace = r"C:\Temp\Test.gdb"
  5.
  6. listFCs = arcpy.ListFeatureClasses("*")
  7.
  8. for fc in listFCs:
  9.     count1 = str(arcpy.GetCount_management(fc))
  10.     if count1 == "0":
  11.         arcpy.Delete_management(fc)
In arcgis pro this scripts is giving my this error
Start Time: zaterdag 9 december 2017 21:22:32
Running script DumpEmptyData...
Failed script DumpEmptyData...
File "F:\GIS_Data\Tools\Python Scripts\DeleteEmptyfields.py", line 21, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 16029, in GetCount
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 16026, in GetCount
retval = convertArcObjectToPythonObject(gp.GetCount_management(*gp_fixargs((in_rows,), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Rows: Dataset not_empty_feature_1 does not exist or is not supported
Failed to execute (GetCount).
Failed to execute (DumpEmptyData).
Failed at zaterdag 9 december 2017 21:22:33 (Elapsed Time: 0,66 seconds)
I now use the count tool to NOT copy features in the first place (this is even better) but it bugs my why it did not work (did not get a error in the analyse tool)
greetings Peter
Outcomes
