Hi everyone. I'm facing a problem trying to extend the FieldMappings class:
When I try do call the constrcutor:
f = FeatureFields(feature)
The terminal give the following errors:
super(FieldMappings, self).__init__()
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\arcpy\arcpy\arcobjects\mixins.py", line 960, in __init__
_BaseArcObject.__init__(self)
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\arcpy\arcpy\arcobjects\_base.py", line 47, in __init__
for arg in args))
RuntimeError: Object: CreateObject FeatureFields not valid
What I'm doing wrong?
have you check what is needed as arguments _base and mixins? can't check those lines
Those line numbers may have changed in 10.5.1
currently 960 is NetCDFFilePropertiesMixin
and the _base will fail since the object has to have an arc_object attribute which may mean subclassing isn't permitted or it failed because it wasn't assigned earlier
((arg._arc_object if hasattr(arg, '_arc_object')
but that could be a line number issue
Yes, in mixins.py line 960 we have: _BaseArcObject.__init__(self)
Complete code:
class FieldMappingsMixin(object):
def __init__(self):
"""FieldMappings()"""
from arcpy.geoprocessing._base import gp_fixargs
def __iter__(self):
return iter(self.fieldMappings)
And in _base.py, line 47 we have:
class _BaseArcObject(object):
_arc_object = None
def __init__(self, *args, **kwargs):
"""Wrapper for ArcGIS scripting Arc Objects --
Create a new object instance if no reference is passed in."""
super(_BaseArcObject, self).__init__()
self._arc_object = gp._gp.CreateObject(self.__class__.__name__,
*((arg._arc_object if hasattr(arg, '_arc_object') else arg)
for arg in args))
for attr, value in kwargs.iteritems():
setattr(self._arc_object, attr, value)
self._go()
