markus001
Export Web Map Task: operational layer not printing using proxy url
Discussion created by markus001 on Dec 11, 2017
We are unable to print out ArcGis Map service layers in conjunction with the esri server proxy.
We use:
- ArcGIS Server 10.4.1
- DotNet resource-proxy-1.1.2
- dotnet 4.5
- http
- anonimous access to printserver and mapservice
We use the dotnet proxy from:
https://github.com/Esri/resource-proxy/blob/master/DotNet/README.md
The proxy successfully returns the response for
http://[proxyUrl]/proxy.ashx?http://services.arcgisonline.com/ArcGIS/rest/services/?f=pjson
http://[proxyUrl]/proxy.ashx?http://[arcGisServerHost]/arcgis/rest/services/folder1/layer1/MapServer/
with http://[arcGisServerHost]:6080/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task/execute
This minimal ExportWebMap specification returns the expected PDF output:
  "operationalLayers": [
"currentVersion": 10.41,
  "id": 0,
  "name": "layer1",
  "minScale": 0,
  "maxScale": 0,
"url": "http://[arcGisServerHost]/arcgis/rest/services/folder1/layer1/MapServer/"
  "exportOptions": {
    "dpi": 96,
    "outputSize": [
      800,
      600
The same ExportWebMap using the proxy returns an empty PDF:
  "id": 0,
  "name": "layer1",
  "minScale": 0,
  "maxScale": 0,
"url": "http://[proxyUrl]/proxy.ashx?http://[arcGisServerHost]/arcgis/rest/services/folder1/layer1/MapServer/"
  "exportOptions": {
    "dpi": 96,
    "outputSize": [
      800,
      600
The proxy service is not event hit. If we add "type": "image", -> the proxy is hit.
According to http://server.arcgis.com/en/server/10.4/create-web-apps/windows/exportwebmap-specification.htm "type" is necessary "If the resource cannot be determined from the URL, the type property defines the type.".
Question 1: Why our proxy is not hit without a "type" attribute specified
Question 2: What would be the appropriate value for "type" for a Esri Map Service?
Outcomes
