ArcMap log file
1236
12-07-2017 02:43 PM
JoeBorgione
How To: Create an ArcMap 10.3 startup log  describes how to create a log file for ArcMap.  However it creates that log file in the <argis install directory>\bin.  I was able to create the logfile there by running the command line window "as administrator".
The problem is I run ArcMap as my normal login, and that log file is in read only area of my c:\ drive.  Is there a way to create a log file that I can actually use?
DanPatterson_Retired
in_memory???
JoeBorgione
LOL!
