I have two renders that I am using to render my Streets. They both work independently but lost on how to get them into the same renderer...because If I try and use them independently it cancels one out.
1st RENDERER
var RoadColor1 = new Color("#eae5e5");
var RoadLine1 = new SimpleLineSymbol("solid", RoadColor1, 1.5);
var RoadSymbol1 = new SimpleFillSymbol("solid", RoadLine1, null);
var RoadRenderer1 = new SimpleRenderer(RoadSymbol1);
RoadBlack1.setRenderer(RoadRenderer1);
2nd RENDERER
//Assign parameters for road width by SPEED
var sizeInfo = {
field:"SPEED",
minSize:.2,
maxSize:10,
minDataValue:0,
maxDataValue:70
RoadBlack1.renderer.setSizeInfo(sizeInfo);
How can I combine them so they both work?
Solved! Go to Solution.
Layers can only have one renderer at a time. What you're attempting to do is possible, you're just confusing the visual variable object with the renderer. visualVariables is a property of the renderer. Just reorganize your code a bit and it should work.
Here's what you need to do:
var RoadColor = new Color("#eae5e5"); var RoadSymbol = new SimpleLineSymbol("solid", RoadColor, 1.5); var RoadRenderer = new SimpleRenderer(RoadSymbol);
//Assign parameters for road width by SPEED var sizeInfo = { type: "sizeInfo", // type must be specified otherwise the renderer //doesn't know which visual variable type it is field:"SPEED", minSize: 0.2, maxSize: 10, minDataValue: 0, maxDataValue: 70 };
RoadRenderer
.setVisualVariables([sizeInfo]); RoadBlack.setRenderer(RoadRenderer);
Jay,
This is very confusing. You are calling the symbol and layer roads (which normally would be a line) but you are applying a SimpleFillSymbol and then trying to use a SizeInfo (which normally is either a marker or a line)... What gives?
Good catch, Robert. Yes, the SimpleFillSymbol won't work for a sizeInfo visual variable.
Jay, Scrap that symbol and stick to a line and you should be good to go with the snippet I added below.
I just updated the snippet to reflect the issue Robert pointed out.
RoadRenderer
Thank you both for your thoughts and help...yea I was confusing myself there...lol....thanks
Gonna test this out and will get back with ya
This is what I have....
No matter what I change the RoadColor to it still comes up green (in the example the Hex color is red)
The LabelClass for the Roads work Fine
I even changed the road width on the SizeInfo to 40 and all the roads are the same width
var RoadEndPoint1 = "https://xxxxx/FeatureServer/11";
var RoadBlack1 = new FeatureLayer(RoadEndPoint1, {
mode: FeatureLayer.MODE_ONDEMAND,
minScale: 50000,
visible: false,
outFields: ["STREET_NAME_FULL", "SPEED"]
// Push layer to the legend
legendLayers.push({ layer: RoadBlack1, title: 'Roads Centerline 2' });
//Create a new Label Class for the Street Labels
var labelClass1 = new LabelClass({
labelExpressionInfo: {"value": "{STREET_NAME_FULL}"},
symbol: {
"type": "esriTS",
"color": [255,255,255],
"haloColor": [0,0,0],
"haloSize": "1.25",
"verticalAlignment": "middle",
"horizontalAlignment": "center",
"yoffset": "0",
"font": {
"family": "Arial",
"size": "12px",
"weight": "BOLDER"
//Apply the labelingInfo to the States feature layer and add to the map
RoadBlack1.setLabelingInfo([ labelClass1 ]);
var RoadColor = new Color("#FF0000");
var sizeInfo = {
type: "sizeInfo", // type must be specified otherwise the renderer doesn't know which visual variable type it is
field:"SPEED",
minSize: 0.2,
maxSize: 40,
minDataValue: 0,
maxDataValue: 70
RoadRenderer.setVisualVariables(sizeInfo);
OK fixed the road color issue....your code snip had
needed to be RoadBlack1
RoadBlack1.setRenderer(RoadRenderer);
Now just need to figure out why the roads are not varying widths
Got it...I removed the [ ] at one point on the line: RoadRenderer.setVisualVariables([sizeInfo]);
ALL GOOD TO GO....THANK YOU ALL SO MUCH
I took the liberty of renaming variables in my snippet. Maybe that's the issue? You're setting labelingInfo on RoadBlack1, but the renderer on RoadBlack.
// should beRoadBlack1.setRenderer(RoadRenderer);
