AnsweredAssumed Answered
ArcGIS Server: incorrect return values of a feature to calculate the extent
Question asked by SandSloper3 on Dec 6, 2017
I start to develop a script to run it on the ArcGIS-Server but hang at the beginning by calculatining the extent of a created Shapefile from a input JSON file. Here I copy all the parsed points into a Shapefile from which i like to get the extent for further calculation steps. If I run my script inside the desktop environment everything works fine but after i published my script on the serverside, the issue is wrong.
Can someone tell me where the mistake is ? I tried everything but was not able to fix ist. The Server and desktopversion is 10.5.1 Here is my little Code:
class Toolbox:
    def execute(self,xy_json,indicator,time,epsg):
        sr = arcpy.SpatialReference()
        sr.factoryCode = epsg
        sr.create()
        # ENV Settings
        arcpy.env.overwriteOutput = 1
        arcpy.env.outputCoordinateSystem = sr
        json_obj = []
        tif = os.path.join(arcpy.env.scratchFolder,'temp.tif')
        # temp file
        temp_shapefile = os.path.join(arcpy.env.scratchFolder, 'temp_shp')
        # the array which stors the values
        pt_geoms = []
        id_pt_array = []
        inputjson = json.loads(xy_json)
        # json string to shapefile
        pt = arcpy.Point()
        for row in inputjson:
            id = row['id']
            pt.X = row['x']
            pt.Y = row['y']
            id_pt_array.append({'id': id, 'x': round(pt.X, 0), 'y': round(pt.Y, 0)})
            pt_geoms.append(arcpy.PointGeometry(pt))
        pt_geometry = arcpy.CopyFeatures_management(pt_geoms, temp_shapefile)
        arcpy.DefineProjection_management(pt_geometry,sr.exportToString())
        # Process: Minimum Bounding Geometry
        ext = arcpy.Describe(pt_geometry)
        xmin = ext.extent.XMin
        xmax = ext.extent.XMax
        ymin = ext.extent.YMin
        ymax = ext.extent.YMax
        out = '{0},{1},{2},{3}'.format(xmin, ymin, xmax, ymax)
        arcpy.AddMessage('{0}'.format(out))
        arcpy.SetParameterAsText(4, out)
def main():
    #user defined values
    xy_json = arcpy.GetParameterAsText(0)
    indicator = arcpy.GetParameterAsText(1)
    time = arcpy.GetParameterAsText(2)
    epsg = arcpy.GetParameterAsText(3)
    tb = Toolbox()
    tb.execute(xy_json,indicator,time,epsg)
if __name__ == '__main__': main()
The correct output on the desktopversion with epsg:3035 is: 4339060.59912, 2763757.46692, 4342628.09351, 2766830.13068
but the script on the server brings as output: 4.33953566875e+13, 276579545.0, 4.34262809349e+14, 2.76683013062e+14
I don't want to do a conversation with the result, because the spatial reference must be flexible by user input.
Thanks for Help !
Outcomes
