dashboard theme not working in mobile
846
6
12-06-2017 04:22 AM
SPNIOrganization
I made an app with WAB and used the dashboard theme.
I chose 3 widgets - layer list, bookmark and info-graphics.
on mobile view - i can only see the first widget as it should be. The other widgets are shown as blank.
you can see the app here:
ArcGIS Web Application
you can change the size of your browser window to be small like a mobile device (don't need to actually use your mobile).
I tried it on 3 different apps and it happens every time.
Any ideas??
thanks,
Dikla.
p.s - I also tried making the app using the WAB for developers, on my server, but there is no change. (v2.5 and also v2.6)
RobertScheitlin__GISP
Dikla,
  In WAB Dev you have the preview button (at the bottom left) that allows you to preview you app on different mobile devices.
SPNIOrganization
OK,
but i still don't understand why I can't see the widgets in mobile view.
do you have any idea?
The dashboard theme is not a very mobile friendly theme in my opinion. It is a theme that should be used for desktop.
SPNIOrganization
thank you.
I was hoping that it could work.
but if you (from all people) say this,  I guess I need to find a different theme 😞
LemaoWu
Dikla,
Your app may not be shared. Dashboard theme should work in mobile screen sizes.  Please find the following screenshot for some tips:
ScottEvans6
New Contributor III
I am having issue with the Dashboard Theme as well. When opening the url link on the mobile phone(IPhone), it centers the screen in others areas, sometimes hundreds of miles away. Also, the info summary widget is greyed out on half of the layers. After refreshing the safari browser several times, it will return to normal, but will always go back to being messed up after another browser refresh. Any updates on a fix, or bug for this??
