detect language in Survey123
535
12-05-2017 04:37 AM
ITDepartment3
Is it possible to detect the language the user has switched to in the Survey123 app and perform a calculation based on the selected language?
We'd like to use that in reports, e.g. show a disclaimer from a Notes field (calculation:if lang1 then text1 else text2) in the language that has been used to capture the entry.
Or is there a better way to get the same result?
JamesTedrick
Esri Esteemed Contributor
I think there is a better way to accomplish this.  Notes, like other questions, support multiple languages - you can place the text1 in the label::<lang1> column and text2 in the label::<lang2> column.
JohnathanHasthorpe
While the field app recognises the locale of the app and automatically adjusts for time zone, language (UI) and units - your requirement would be to localise the form content. To do this you would need to translate your labels, as detailed here: Multiple language support—Survey123 for ArcGIS | ArcGIS
The only limitation of this method is that the user would have to manually select the right language in the form (it would not be automatic).
