JB1234510
Workspace to RasterDataset doesn't work?
Discussion created by JB1234510 on Dec 1, 2017
Latest reply on May 18, 2018 by JB1234510
if I use the following python script to create a fgdb with a raster dataset this works, but the raster dataset remains empty. So the command arcpy.WorkspaceToRasterDataset_management doesn't do anything. There's no error message.
import arcpy
from arcpy import env
# Local variables:
RasterCatalog_gdb = arcpy.GetParameterAsText(0) # FileGDB
PfadFGDB = arcpy.GetParameterAsText(1) # Pfad FGDB
Dataset = arcpy.GetParameterAsText(2)# Raster Catalog
PfadWorkspace = arcpy.GetParameterAsText(3) # Workspace mit Bildern
RasterGdb = PfadFGDB + "/" + RasterCatalog_gdb + ".gdb"
arcpy.AddMessage(RasterGdb)
DatasetPfad = PfadFGDB + "/" + RasterCatalog_gdb + ".gdb" + "/" + Dataset
arcpy.AddMessage(DatasetPfad)
try:
    # Process: File-Geodatabase erstellen
    arcpy.CreateFileGDB_management(PfadFGDB, RasterCatalog_gdb, "CURRENT")
    # Process: Raster-Dataset erstellen
    arcpy.CreateRasterDataset_management(RasterGdb, Dataset, "0,2", "8_BIT_UNSIGNED", "PROJCS['DHDN_3_Degree_Gauss_Zone_3',GEOGCS['GCS_Deutsches_Hauptdreiecksnetz',DATUM['D_Deutsches_Hauptdreiecksnetz',SPHEROID['Bessel_1841',6377397.155,299.1528128]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Gauss_Kruger'],PARAMETER['False_Easting',3500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',9.0],PARAMETER['Scale_Factor',1.0],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]", "3", "", "PYRAMIDS -1 NEAREST LZ77 75 NO_SKIP", "128 128", "LZ77", "")
    arcpy.env.pyramid = "PYRAMIDS 3 BILINEAR JPEG"
    arcpy.env.rasterStatistics = "STATISTICS 4 6 (0)"
    arcpy.BuildPyramidsAndStatistics_management(PfadWorkspace, "INCLUDE_SUBDIRECTORIES", "BUILD_PYRAMIDS", "CALCULATE_STATISTICS")
    # Process: Workspace in Raster-Dataset
    arcpy.WorkspaceToRasterDataset_management(PfadWorkspace, DatasetPfad, "NONE", "LAST", "MATCH", "", "", "NONE", "0", "HISTOGRAM_MATCHING", "NONE")
except:
    print "failed"
    print arcpy.GetMessages()
Could it be that the dataset definition don't fit with the type of raster source files?
Dataset:
Raster Source file (jpeg):
I don't find any differences.
Or is it something with the calculation of statistics?
If I use the toolbox tools to load the data manually into the dataset, there's as well no error message and there's afterwards the same empty dataset although the tool message ends with a sucessful loading of the data.
Outcomes
