Why does not FeatureLayer support sub layers?
306
11-29-2017 03:46 AM
LarsFagerbakke
New Contributor III
From what I can gather FeatureLayer does not support sub layers. Why not?
The workaround is implementing the layer as a MapImage layer, I can still add a popup on it. But now I lost search! The search widget only supports FeatureLayer and this Locator thingy.
Its a bigger workaround implementing this as a MapImageLayer, for making it hold a lot of data as if were a FeatureLayer to be able to set up the search source.
Tags (1)
RobertScheitlin__GISP
Lars,
   It has always been this was in the JS API. A feature layer returns actual geometry from the server that is rendered client side (which can be very costly on client side resourses). Where a MapImageLayer (what use to be an ArcGISDynamicMapServiceLayer) is rendered on the server and a image is returned. Having a FeatureLayer allow sublayers would be detrimental to the client browser resources most likely.
ReneRubalcava
Like Robert said, FeatureLayers reference a single resource. If you want to do something similar to MapImageLayer with FeatureLayer, you might want to look at GroupLayer.
I made a video about this not too long ago.
GroupLayers in your ArcGIS JSAPI apps - YouTube
It let's you group the Layers into a single layer that can be passed around and managed.
