Listen to any published recently service on ArcGIS Server
1467
13
11-27-2017 11:38 PM
MarkMindlin_idea
New Contributor III
We are thinking what approach could be to handle event of publishing (successfully) a service on ArcGIS Server. Could it be done with a server extension? How?
ArcGIS Server 10.5.1. (No ArcGIS Portal)
Any help please.
RandallWilliams
Can you elaborate a bit on what specifically you'd like to achieve? I'm unsure there's enough information to provide guidance at this point.
MarkMindlin
Occasional Contributor III
We want to run a Python script/executable (on a server where a ArcGIS Server installed) every time any service published (successfully) on the ArcGIS Server. We have no ArcGIS Portal.
RandallWilliams
An approach could be to periodically run a quick query on the logs using the admin API , looking for log code 23840 (service published). Dump the datestamps in a file, then do a diff/compare against a file created from a previous run. If the result of the compare between the 2 files = false, run the script.
The response to the log query would be similar to the following.
{       "type": "INFO",       "message": "Service published [name: 123123123123123; type: MapServer].",       "time": 1511902237075,       "source": "System/PublishingToolsEx.GPServer",       "machine": "machine.domain.COM",       "user": "0123456789ABCDEF::someuser",       "code": 23840,       "elapsed": "",       "process": "24509",       "thread": "112",       "methodName": "pubSD.Execute"     },     {       "type": "INFO",       "message": "Service published [name: ausmap_WFL1; type: FeatureServer].",       "time": 1509544574338,       "source": "System/PublishingTools.GPServer",       "machine": "machine.domain.COM",       "user": "someuser",       "code": 23840,       "elapsed": "",       "process": "19996",       "thread": "73",       "methodName": "pubSD.Execute"     },
Example: Query the ArcGIS Server logs—Documentation (10.3 and 10.3.1) | ArcGIS for Server
MarkMindlin_idea
New Contributor III
Thanks Randall,
Could you please send a link to list of log codes includes 23840.
JonathanQuinn
Esri Notable Contributor
Perhaps you can look at the lifecyclesinfo for each service:
http://server.domain.com:6080/arcgis/admin/services/SampleWorldCities.MapServer/lifecycleinfos
This will return when the service was created and last stopped, started, or edited:
    "lifecycleinfos": [{
        "user": "",
        "timestamp": 1499448691252,
        "type": "created"
        "user": "",
        "timestamp": 1499448691270,
        "type": "started"
        "user": "admin",
        "timestamp": 1511979284702,
        "type": "stopped"
    "lastmodified": 1511979284702
Potentially, you can run your script every X minutes and then loop through all services and check whether the service has been created within the last X minutes.
MarkMindlin_idea
New Contributor III
Thanks Jonathan,
But the API you provided /lifecyclesinfo
doesn't work
Should we switch on something on the service?
JonathanQuinn
It should be available already.  Can you describe what you mean by doesn't work?
MarkMindlin_idea
New Contributor III
Sorry, but your link returns
ERROR
The requested URL could not be retrieved
We have the service
public/NSW_Administrative_Boundaries (MapServer)
We tried to apply your sintax /lifecyclesinfo
"http://maps.six.nsw.gov.au/arcgis/rest/services/public/NSW_Administrative_Boundaries/MapServer/lifecyclesinfo"
It does not work.
JonathanQuinn
You access the lifecyclesinfo page through the Admin API, not the REST directory:
