AnsweredAssumed Answered
Survery123 Apps in Portal 10.5.1
Question asked by SJehle on Nov 21, 2017
Latest reply on Nov 21, 2017 by Bethany_Berry-esristaff
I have installed ArcGIS Enterprise 10.5.1 to start testing out all of Portal's capabilities and on that list is Survey123. I'm using Survey123 Connect (v2.4.60) to publish surveys to a hosted server, however when it gets the form item it gets stuck and never finishes. After going through the Survey123 Connect logs and various community posts, I was unable to narrow down the problem. I have tested the Survey123 Connect in a second portal 10.5.1 instance and it publishes the form item with no problem, so all signs pointed to an issue with the portal environment installation.
After doing some digging, I found out that a Survey123 for ArcGIS application now gets created within the Portal 10.5.1 install. I went to the Portal sharing rest API and found there are three Survey123 for ArcGIS apps that have been created by the esri_apps users (picture attached). I did the same search on the second portal and found that there should only one entry. I'm guessing the issue is cause by having three applications, so I would like to delete the two unnecessary apps. The problem is, I do not know how to delete apps that have been created by the esri_apps users. There are a few other developers in the environment so reinstalling and starting from scratch is a last resort. My question is, is there a way to delete the 2 apps that have been created by the esri_apps user?
Thanks!
Outcomes
