Bridge Pier Occlusions
442
11-17-2017 06:32 AM
JesseSuders4
I have created a bridge and there is a pier occlusion. Is there a way to fix this so that occlusions are avoided? I am using the complete streets rule.
JesseSuders4
I have determined to solution. Firstroads must be drawn in order  of lowest to highest (ground level up). Second you must use display praise regaurdless as you drudge setting. This keeps bridge piers off of underlying roads. If you draw a road under a bridge, the piers will not recognize it or readjust.
DavidWasserman
Occasional Contributor III
Hi Jesse,
If you have a CS Rule question you want me to review, just tag me with David Wasserman or you can post to the https://community.esri.com/message/443977 page.
Glad you found a solution.
David
David Wasserman, AICP
