is it possible to create a costum widget, that shows push messages? For example if the webmap was changed, that the user reloads the webmap application? Or has someone other ideas?
Karsten
Solved! Go to Solution.
Hi, what do you mean by webmap have changed? as in change in layers or change of basemap?
The ArGIS javascript API are largely event driven:
https://developers.arcgis.com/javascript/3/jshelp/inside_events.html
Hope that helps
Sure it can !
You'll need to create this in a theme though, this because widget's lifecyle ony start from the moment it has been openend.
Tip: have a look into Dojo Publish ...
Hope that helps
