Change fonts in WAB 2.6
1215
14
11-14-2017 07:23 AM
GeorgeKatsambas
Occasional Contributor III
To change title fonts for all my widgets do I have to change each individual css file? For example in the Measure widget I want to change the font size of measure.
RobertScheitlin__GISP
George,
  No you can add this new css rule to your apps theme common.css file:
.jimu-on-screen-widget-panel>.jimu-panel-title>.title-label,
.jimu-foldable-panel .title-label {
  font-size: 22px;
George,
  font-size: 22px;
GeorgeKatsambas
A few months ago you also helped me with changing the color
.FoldableTheme.default .jimu-on-screen-widget-panel > .jimu-panel-title {
  background-color: rgb(255, 0, 0);
  background-color: rgba(255, 0, 0, 1);
I can add this rule in the same place right? Do i need the Bold text as well?
WAB DE 2.6
George,
   Yes and Yes if you are using the foldable theme.
GeorgeKatsambas
If i add .FoldableTheme.default  nothing happens, if i add
@import url("panels/FoldablePanel/style.css");
@import url("panels/DockablePanel/style.css");
/********** styles for simple panel***********/
.jimu-simple-panel{
-moz-border-radius: 4px;
-webkit-border-radius: 4px;
border-radius: 4px;
font-size: 25px;
background-color: rgba(255, 0, 0,);
I get this, I assume my syntax is wrong somewhere?
George,
Try this:
.jimu-simple-panel{
  border-radius: 4px;
  font-size: 25px;
GeorgeKatsambas
Thats not changing the color
George then try putting it like this:
.jimu-simple-panel{
  border-radius: 4px;
  font-size: 25px;
GeorgeKatsambas
That does not work either, is it because the map was created in 2.5 and imported into 2.6?
George,
   What theme are you using? I just tested again in 2.6 using the Foldable Theme and it looks like this:
Are you taking about the HeaderController widget panel not having the red color?
