Map “navigation” tools are greyed out while working with layout in ArcGIS Pro,
5464
11-15-2017 12:28 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why Map “navigation” tools are greyed out while working with layout in ArcGIS Pro. Then how one can zoom to full extent for example?
Jamal Numan
XanderBakker
Esri Esteemed Contributor
Are you sure that you don't have a Fixed extent or something similar set to the selected Map Frame? This would disable the navigation buttons.
CarmelConnolly
Hi Jamal,
What version of ArcGIS Pro are you using?
Do you have any edits that need to be saved?
Are the tools greyed out with all the map frames?
If you click 'Activate', are you able to change the map extent/zoom?
Carmel
XanderBakker
JamalNUMAN
Many thanks Xander for the help. Changing the constraint to “None” has solved the issue
Jamal Numan
JamalNUMAN
Hi Carmel,
As all the time the version of Pro is required to be recognized, why not to show it in the title bar as indicated in the thread below. For me, I do prefer to add screenshots as they are much more powerful to convey the issue.
Is there a way to display the ArcGIS Pro version in the title bar?
https://community.esri.com/thread/204907-is-there-a-way-to-display-the-arcgis-pro-version-in-the-tit...
Jamal Numan
