Arcmap 10.4.1 Hangs on Initializing license
6743
7
11-14-2017 07:06 AM
MoMohamad
New Contributor III
I have Single use license , Arcmap 10.4.1 Hangs on Initializing license and keeps initializing for long time without lunching arcmap , I've tried many things , completely uninstall and install arcgis , change windows profile , change my license to concurrent , disconnect my internet connection ,  nothing worked !!
Tags (1)
GeorgeDurkee
After installing new license from my college, I had this problem. Tried all fixes above (though didn't reinstall yet). But, from this thread, found if I turned off Ineternet connection to keep it from checking online for license (?), it started right away! ArcMap gets stuck 'Initializing licences' : gis  It doesn't make sense that I'd need to be connected to our school's server. Same license works on my other computer. But, anyway, this seems to have fixed the problem though not ideal solution..
JayantaPoddar
MVP Esteemed Contributor
Try these steps:
1. Deauthorize licenses
2. Clear Trusted Storage. http://support.esri.com/en/technical-article/000011660
3. Authorize the licenses.
In case the issue still persists, you should get in touch with Esri Tech Support to resolve the issue.
Think Location
MoMohamad
New Contributor III
i tried this but didn't work
DamijanMavrinac
is there any update with this issue?
MoMohamad
New Contributor III
 problem solved by formatting windows
by Anonymous User
Not applicable
Uninstalling ArcMap and renaming the FLEXnet file referenced in the above linked article to FlexNet_Old fixed the issue for me.
GeorgeDurkee
DuncanHornby
MVP Notable Contributor
My new laptop is not opening ArcMap 10.8.2 from home, just gets stuck at initializing license.  Finally discovered this mad solution! I turned off wifi on my laptop, start Arcmap, it finally opens, then turn back on wifi... Nuts...but it works! 😃
