WABde 2.6 wont start...
1289
14
11-12-2017 03:19 AM
ErikLanhammar
So Im trying to run wabde 2.6 on my local machine but I get an error message re body-parser deprecated...
Some googling suggested using below...
app.use(bodyParser.urlencoded({  extended: true}));
...before calls to app.use(bodyParser....) in server.js .
Tried it but without success. Any ideas how to solve this?
Rgds,
/Erik
Starting node from commando prompt:
C:\Archive\ESRI\wabde\wabde26_oktober download\WebAppBuilderForArcGIS\server>node_x64.exe server.js -port=3344
body-parser deprecated bodyParser: use individual json/urlencoded middlewares server.js:206:11
body-parser deprecated undefined extended: provide extended option node_modules\body-parser\index.js:105:29
Server listening tcp connection on port 3344 in development mode
[2017-11-12 11:50:26.670] [INFO] repo - Read repository items: C:\Archive\ESRI\wabde\wabde26_oktober download\WebAppBuilderForArcGIS\client\stemapp\widgets
events.js:141
throw er; // Unhandled 'error' event
Error: listen EACCES 0.0.0.0:3344
at Object.exports._errnoException (util.js:873:11)
at exports._exceptionWithHostPort (util.js:896:20)
at Server._listen2 (net.js:1237:19)
at listen (net.js:1286:10)
at Server.listen (net.js:1382:5)
at Object.<anonymous> (C:\Archive\ESRI\wabde\wabde26_oktober download\WebAppBuilderForArcGIS\server\server.js:115:23)
at Module._compile (module.js:409:26)
at Object.Module._extensions..js (module.js:416:10)
at Module.load (module.js:343:32)
at Function.Module._load (module.js:300:12)
RobertScheitlin__GISP
Erik,
  That is not an error it is just a warning that has been there since 2.5. It will not prevent the app from working properly.
ErikLanhammar
Robert,
Thanks for your reply. Node never starts, and the dos window shuts down. I have had wabde installed for a month or so and it used to work (the dos window would stay open and I could see calls to wab in it). But now it shuts down a few secs after I right click it and select Run as Admin... The default browser starts to call http://<mymachine.domain>:3344/webappbuilder but without hitting node...
/Erik
Erik,
  I have not seen the:
events.js:141
Do you have a widget that has a events.js file?
ErikLanhammar
Sorry, no events.js in the ...\client\stemapp\widgets folder.
/E
Erik,
   Sounds like a corruption of your WAB install. You should re-install WAB. If you are wanting to save some apps from you now defunct WAB then make sure to install the fresh version using a different folder name then the previous one, that way you can copy the server db folder and apps folder from the old to the new.
ErikLanhammar
OK, I did that, the location: C:\Archive\ESRI\wabde\wabde26_oktober download\WebAppBuilderForArcGIS\.. is my second download attempt, since the original WABde I have in C:\Program Files\ArcGIS\wabde\arcgis-web-appbuilder-2.6\WebAppBuilderForArcGIS started to behave...funny...
But Ill redo the whole thing and see if I can find out whats wrong...
/E
RebeccaStrauch__GISP
I would also try to avoid spaces in your path name.   (e.g.  the space between oktober and download)
ErikLanhammar
So I downloaded again, but the same result...  Here's what it looks like when I run startup.bat. I added a '& Pause' at the end of line 30 in startup.bat just to make the window stay open, without it the window shuts down after 5 secs.
What is going on?!
Rgds/
Erik
Erik,
  As a test try moving the WAB app out of the Program Files folder to just the root of the C:\
