How can I use Attribute Assistant to copy the ObjectID field into another field in the same layer
394
11-07-2017 07:05 AM
TaraSpinos
I have attached an image of my current dynamic value table. I filled out the fields based on Esri's instructions for the Field Method (All methods - Attribute Assistant | ArcGIS Solutions )
I have a layer called MidlandGIS.SDE.BM_EsiteAddr
I want the ObjectID to copy into the Energov_ID field when a new feature is created
When I create a new address feature, the energov ID field is not being populated. I am also not using alias field names in the dynamic value table.
Any help on what I have wrong in my dynamic value table would be appreciated.
Tags (1)
