Is there a way to make conditions on a "Select One" question that will apply to another "Select One" question. For instance, I'm building a survey that has a Select One question where users can pick from a list of School Districts. I would like the next question to then be a Select One on schools, but I would like only the schools that are within the above selected School District to be pulled. Is that possible? I'm currently building this survey online, where I know this is not a possibility, but I could easily switch to Connect if that will provide me with more options.
Many thanks!!
Solved! Go to Solution.
Hi Grace
The functionality you describe here is called a cascading select. This is where you have two select_one questions, and the first one filters the options in the second. We have a sample available through Connect (called Cascading selects!) which will give you a start.
There is also a blog about them here: https://community.esri.com/groups/survey123/blog/2015/10/22/cascading-selects-and-external-selects
Please let me know if you need any help with this.
John
Hi Grace,
Yes, there's something to do exactly this in Survey123 Connect! What you're looking for is covered well by cascading selects.
Cascading and external selects—Survey123 for ArcGIS | ArcGIS
Hi Grace
John
