Python Help needed
1345
11
11-02-2017 12:09 PM
StevenFama
I have a script that populates/updates a field based upon its content. If none of the conditions are true, I need it not to update / return <Null>.
def Reclass(StoryHeight_Copy):
if (StoryHeight_Copy == "1A"):
return "1.25"
elif (StoryHeight_Copy == "1H"):
return "1.50"
elif (StoryHeight_Copy == "1T"):
return "1.75"
elif (StoryHeight_Copy == "2A"):
return "2.25"
elif (StoryHeight_Copy == "2H"):
return "2.50"
elif (StoryHeight_Copy == "2T"):
return "2.75"
elif (StoryHeight_Copy == "3A"):
return "3.25"
elif (StoryHeight_Copy == "3H"):
return "3.50"
elif (StoryHeight_Copy == "3T"):
return "3.75"
DanPatterson_Retired
First, reformat your code then if add
else:
    return None‍‍‍‍
The above will return <null>
otherwise, if you don't want <null>
else:
    return "something else"‍‍
You have to return something, it is either None (aka ) or something
else:
    return None‍‍‍‍
else:
StevenFama
I want it to return what is in another field or just leave what is in the existing cell
StevenFama
AS you can see, I created a field *_Copy.  when I run the script above, it works till the 'IF' is false. Then it updates to null.  I want it to leave what is already there 1, or 2, or what ever else is their.
curtvprice
MVP Esteemed Contributor
Is this Pro or ArcMap? Are you using the Calculate Field tool?
StevenFama
ArcMap using the field calc.
curtvprice
Sometimes https://community.esri.com/community/developers/gis-developers/python?sr=search&searchId=05a9d169-b0... is simpler than one thinks.
Like Dan said, try:
else:
    return StoryHeight_Copy
StevenFama
Thank you.  That worked!!!!
XanderBakker
Esri Esteemed Contributor
Just an additional comment to put in my two cents.
When the list of possibilities gets a bit long you can use dictionaries: See the example below:
def Reclass(story_height):
    dct = {"1A": "1.25", "1H": "1.50", "1T": "1.75",
           "2A": "2.25", "2H": "2.50", "2T": "2.75",
           "3A": "3.25", "3H": "3.50", "3T": "3.75"}
    if story_height in dct:
        return dct[story_height]
    else:
        return story_height
 This allows you to search for a key in the dictionary and if it exists it will return the corresponding value.
Since I notice that there is a logic in the values returned, in this case you could also do this:
def Reclass2(story_height):
    dct = {"A": ".25", "H": ".50", "T": ".75"}
    result = story_height
    if len(story_height) == 2:
        if story_height[1] in dct:
            result = story_height[0] + dct[story_height[1]]
    return result
The A, H and T value represent the value (ok, text) behind the decimal and just put the first character in front of it.
When you run it (as shown below in a snippet of Python, not the Field Calculator) you can see the result:
def main():
    lst_story_height = ["2H", "3T", "1A", "4H", "5A", "6T"]
    print "\nOriginal methode: Reclass:"
    for story_height in lst_story_height:
        print story_height, Reclass(story_height)
    print "\nAlternative methode: Reclass2:"
        print story_height, Reclass2(story_height)
    else:
        return story_height
    return result
if __name__ == '__main__':
    main()
This will yield:
2H 2.50
3T 3.75
1A 1.25
4H 4H
5A 5A
6T 6T
2H 2.50
3T 3.75
1A 1.25
4H 4.50
5A 5.25
6T 6.75
carlanderson2
your code could be shorter and cleaner as
   d = {"1A":"1.25","1H":"1.5","1T":"1.75"....}
   if StoryHeight_Copy in d:
        return d[StoryHeight_Copy]
   return None
