How do I choose the most centally located
871
9
11-02-2017 09:48 AM
BrandonAdcock1
I have a set of offices and a set of inspection locations.  I would like to equally distribute the inspections to the closest (as the crow flies) field office.  (i.e. 4 offices, so each one is assigned the 1/4 of the inspections closest to it).  Is there a way to do this that doesn't involve too much hassle?
Thank you in advance.
curtvprice
MVP Esteemed Contributor
I want to assign them to the second closest office and keep each of the offices with an equal number of inspections.  That second part is the one I'm having trouble with.
Use the Point Distance tool and sort and select the output table.
DanPatterson_Retired
To divide space equally in raster world, just try
Euclidean Allocation
with the usual caveat of specifying a reasonable cell size and extend and using a projected coordinate system and saving the resultant raster to a folder without a space or other weird characters, with a *.tiff extension plus anything else I have omitted.
BrandonAdcock1
Thank you.  My data is currently stored as points for both the inspection locations and offices.  Not sure that a raster could express the data, but maybe...
Then the alternative is to produce a Voronoi Diagram (aka Thiessen Polygons) around your points... assuming you have an advanced license. orrrrr. the always free at any license level
Triangulation tools ....
There is always a hassle unless you have the correct license and software and don't need it for a while
BrandonAdcock1
Thiessen Polygons are a cool analysis I didn't know was there.  Thanks.
It doesn't take care of the component of making sure the inspections are equally allocated among the offices though.
curtvprice
You didn't see what software you were using. In ArcMap, if you right click your inspection sites, Joins and Relates, Join, by location to offices and pick nearest, you'll get the answer you want. Alternatively, you can use the Spatial Join tool (ArcMap or Pro) to do this - it's a bit more complicated, but it does work. None of these tools require more than a Basic license.
Finding the nearest feature—Help | ArcGIS Desktop
Spatial Join—Help | ArcGIS Desktop
BrandonAdcock1
Thank you for the help.
I am using ArcMap, but have access to Pro as well.
This tells me the closest office, but does not allocate them equally.  What it comes down to is I have one office with a bunch of inspections close to that office.  I want to assign them to the second closest office and keep each of the offices with an equal number of inspections.  That second part is the one I'm having trouble with.
That is getting more complicated and may involve using the Near tools then parsing your preference/allocation list once one hub is filled.
curtvprice
BrandonAdcock1
Thank you Curtis Price‌ and Dan Patterson‌ for the thoughts.  I ended up using the Point Distance Tool and sorted the output table for the top 1/3 of facilities at each of the field offices.  That looks to have gotten me what I needed.  I was hoping for something more elegant and automated, but got the job done, so that's a win for me.
