Display point as Numbered Symbol
1490
10-31-2017 08:28 AM
GregWolowich1
New Contributor III
I'm looking to replicate what was done in this story map:
http://townofbluffton.maps.arcgis.com/apps/MapSeries/index.html?appid=fcb6f07fbd594033a23d3289f29a72...
Where the number on the map corresponds to the accordion item on the left.
The numbers on the map appear to behave like a point symbol and not a label but I'm unsure how to symbolize based on an attribute.
Tags (3)
JayantaPoddar
MVP Esteemed Contributor
Looks like Labels. You could create the same labels in ArcMap, and then publish to ArcGIS Online.
1. Here is my point layer.
2. Enabled colored text background.
3. Changed the placement properties to place the label on top of point.
4. Changed Point Symbology to NoColor (also unchecked "Use Outline" option)
5. Here is how my point layer looks now, after enabling Labeling.
Think Location
GregWolowich1
New Contributor III
I attempted this previously but the labels will not publish to AGO. Possibly because I'm publishing as feature access and not tiled mapping?
JayantaPoddar
The point layer in the above story map looks like a tiled layer though.
Think Location
