Changed DNS, now portal is broken.
2191
5
10-30-2017 07:46 AM
travisslack1
New Contributor III
Hey folks,
We recently switched internet up in the office which entailed the web mapping server getting a new DNS. This has broken Portal  Now, this is the page I get.
Main Portal Page
web.vectorgeomatics.com load my test page fine, web.vectorgeomatics.com/portal/home gives me said error.
If I remote desktop into the server that portal/server is hosted on and I go start > arcgis web adaptor (portal or server) it tries to load the localhost https://localhost/portal/webadaptor and I get the "There is a problem with this website’s security certificate." and If I hit continue it just loads "The webpage cannot be found".
Anyone have any quick ideas that might fix this short of having to reinstall /  re set everything up? Thanks
Tags (3)
harleypowers_parks
New Contributor III
what do you mean by "new DNS"?
Instead of using the localhost, use the full name of the machine like: "https://mymachine.dom1.dom2.com:7443/arcgis/home" confirm this works first.
travisslack1
New Contributor III
Hey Harley,
We recently got a new ISP which involved us receiving a new static IP address...I am not sure what that entailed changing on the back end, but now I can't really load anything.
Loading the mymachiene.dom1.dom2 also didnt work either, "this page can't be displayed'. Services.msc shows both portal and server running.
harleypowers_parks
New Contributor III
try the ..:7443/arcgis/adminpanel  and look at the log files.
if this is not working, then look in the portal's log files located here: <arcgisportal site location>\logs\<your machine name>\portal
There should be some errors that make it a little more clear what's going on.
you may need to talk to your network person at some point.
if you just want to look, in windows, using a command prompt or powershell, and check the network configuration.. "ipconfig /all" will tell you what the machine name is and what ip is and confirm with the network person if it's right.
ipconfig /all
<returns something like>
Windows IP Configuration
Host Name . . . . . . . . . . . . : TEST-Machine-N1
Primary Dns Suffix . . . . . . . : test.machine.com
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : test.machine.com
pwc.uis
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/1000 MT Network Connection
Physical Address. . . . . . . . . : 00-50-65-FA-74-FC
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 60.80.170.144(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 60.80.170.129
DNS Servers . . . . . . . . . . . : 190.160.240.20
NetBIOS over Tcpip. . . . . . . . : Enabled
JonathanQuinn
Esri Notable Contributor
Did the domain name of the portal change, or simply the DNS server but the original domain name was retained?
travisslack1
New Contributor III
DNS server, domain name retained. Had no idea what happened, ended up reinstalling Portal and its normal again. Thanks for the help folks.
