WAB application on mobile devices
1312
19
10-31-2017 06:32 AM
DanielMunoz
Application works fine on iPhone but on the iPad I get:
json parse error unrecognized token '<'
any suggestions
DanielMunoz
I just figure it out, I was missing the "s" on https://
RobertScheitlin__GISP
Daniel,
   On the iPad are you using Safari or Chrome?
DanielMunoz
I tried both with the same results, clear cache on both also.
Is it a public site I can test. I have not had any issue with my site on an iPad.
DanielMunoz
Thank you Robert! I just started moving to WAB from flex, I forgot that for whatever reason when I add my layers to my maps that I going to be using on my WAB app I can only add from my secure GIS server making the app only https://. I see that your widgets live preview sites are not secure, I will have to investigate how to allow http:// sites also. My sites are public but they are only tests for now, interestingly enough I can get to my sites from my PC with only http://  i just get the message this is not a secure site.
ArcGIS Web Application
Daniel,
   The normal culprit for the required https when using WAB is that you entered a https url when you set the portal url when first setting up WAB Dev. If you go to the [instal dir]\server and delete the signininfo.json file and then restart WAB it will ask for the portal url again and this time use http not https.
DanielMunoz
Good to know! I already have a long list of tips. Thank you.
RebeccaStrauch__GISP
Since you are just new to WAB, for other tips, news, training, and widgets, check out my blogs..starting with
/blogs/myAlaskaGIS/2016/03/09/web-appbuilder-developer-edition-customization-resource-list?sr=search...‌
A bit messy, but I update often.  fwiw.
DanielMunoz
Thank you!
DanielMunoz
