set label expression in ArcGIS Pro task
202
10-27-2017 01:44 PM
AwesomeEvan
I'm creating a very basic arcgis pro task which 1) Removes join 2) Add Join
This simply refreshes records used for labelling for a monthly hardcopy print out
I'm doing this becasue I dont think you can (easily) label based on related records
This task breaks my label expression however (not sure why)
The label expression is set to:
[GIS_CORE.DBO.plnPlanningApplications.Applicant] & vbCrLf & [GIS_CORE.DBO.plnPlanningApplications.FileNum]
After the successful remove/add join the labels mess up because the expression gets changed to:
[GIS_CORE.DBO.plnPlanningApplicationProperties.Applicant] & vbCrLf & [GIS_CORE.DBO.plnPlanningApplications.FileNum]
Note:
plnPlanningApplicationProperties = feature class
plnPlanningApplications = related table
My main question then is can I simply force set the label expression each time in the task?
You can choose "label expression..." as a command but how do I add any parameters?
Any guidance would be greatly appreciated.
Cheers.
