Why the “map frame” tool gets greyed out while working with layout in ArcGIS Pro?
2311
10-29-2017 12:05 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why the “map frame” tool gets greyed out while working with layout in ArcGIS Pro.
Jamal Numan
DanPatterson_Retired
It seems like you already have a map frame on the layout.   The other tools associated with the existing map frame are enabled (ie grid)
  Perhaps try an empty layout and see if it becomes enabled
JamalNUMAN
Thanks Dan.
There should be something wrong with my ArcGIS Pro. It doesn’t have a stable behavior.
I restarted the Pro, and I found out that the “map frame” sometimes work and in other cases fail. The same thing can be said regarding other tools that they are supposed to work while working in the layout mode.
What might be the issue here? Bug? Do I need to reinstall it? It is 1.4
Jamal Numan
We are at version 2.0.1... any reason to stay at 1.4?
BeccaBourson1
Within Element symbology options for map frame, select 'options' tab, under map frame (near bottom), uncheck "Use map background color".
