SDK 100.1 Show the map legend
1381
10-25-2017 09:19 AM
DavidHoxeng
First let me say that this community is awesome for us new arcgis users!
I have been able to pull the map in and everything is working fantastic, except that I am not able to figure out how to display the legend for a map.  This is my last item needed for my project.  I am pulling the map in via portal id.
Any help would be greatly appreciated!
Thanks!
AlexanderNohe1
Occasional Contributor III
I don't believe that there is a Legend view built into the API, but what you can do is for each layer in the map, call Layer| arcgis-android fetchLegendInfoAsync and when it is returned, build the legend from the information provided into any view you wish.
I hope this helps!
AlexanderNohe1
I hope this helps!
DavidHoxeng
Thank you for the response!  So for the layers, would these be the operational layers for the map (ArcGISMap.getOperationalLayers())?
AlexanderNohe1
Yes
ShellyGill1
To futher Alexanders reply above, there's a great example of using this method to build a TOC in the Offline Mapbook example app. The app is described here - Offline Mapbook for Android | ArcGIS for Developers  - this topic also includes a link to the source code on GitHub so you can use this as a starting point if this helps.
