I'm creating a new webmap in version 4.5, and am setting the initial extent by using the center+zoom properties.
Works all nice and good, but then when i later try to get the extent, mapview.extent returns null.
Apparently when you use center+zoom, the extent then never gets set?
This sounds like a bug to me.
I need those extent values for some other calculations. Any idea how to get them or calculate them?
Emory H
Solved! Go to Solution.
Emory,
I just tested and I could get the extent just fine.
Are you waiting for the view to be initialized?
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Intro to MapView - Create a 2D map - 4.5</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.5/esri/css/main.css">
<script src="https://js.arcgis.com/4.5/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"dojo/domReady!"
], function(Map, MapView) {
var map = new Map({
basemap: "streets"
var view = new MapView({
container: "viewDiv",
map: map,
zoom: 4,
center: [15, 65] // longitude, latitude
view.then(function(){
console.info(view.extent);
</script>
</head>
Emory,
<!DOCTYPE html>
<html>
<head>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
"dojo/domReady!"
var map = new Map({
basemap: "streets"
map: map,
zoom: 4,
</script>
</head>
Ah, sounds like a good idea... I'll try that.
Slightly Later: It worked too! Thanks!
lines 36 - 38 in my sample above show the proper way to do it.
Don't forget to mark your question as answered by click on the "Mark Correct" button on the reply that answered your question.
