Getting “isWebMercator” Error When Trying To Draw a Circle On Graphics Layer
1444
9
10-24-2017 12:05 PM
BehrouzHosseini
can you please take a look at this snippet and let me know why I am getting this Error message
Uncaught TypeError: Cannot read property 'isWebMercator' of undefined
from the Circle.js module?
var graphicsLayerPoint = new esri.layers.GraphicsLayer();
map.addLayer(graphicsLayerPoint);
var graphicsLayerCircle = new esri.layers.GraphicsLayer();
map.addLayer(graphicsLayerCircle);
$("#btnAddJunctionFlag").on("click", function () {
        toolbar = new Draw(map);
        toolbar.activate(Draw.POINT);
        map.hideZoomSlider();
        toolbar.on("draw-end", addToMap);
        function addToMap(evt) {
        circle = new Circle({
            center: evt.mapPoint,
            geodesic: true,
            radius: .6,
            radiusUnit: "esriMiles"
    var cgraphic = new Graphic(circle, circleSymb);
    graphicsLayerCircle.add(cgraphic);
    var pgraphic = new Graphic(evt.geometry, config.symbolPointJFlag);
    graphicsLayerPoint.add(pgraphic);
RobertScheitlin__GISP
Bengi,
   Simple, it would look like this:
$("#btnAddJunctionFlag").on("click", function () {‍
  if(clickEvtHandler){
    clickEvtHandler.remove();
  clickEvtHandler = map.on("click", function(evt){
      geodesic: true,
      radius: .6,
    var pgraphic = new Graphic(evt.mapPoint, config.symbolPointJFlag);
Of course this would now work best using a dojo ToggleButton instead of a standard button:
dijit/form/ToggleButton — The Dojo Toolkit - Reference Guide
Bengi,
   I am not seeing why you are getting that error, but line 24 in your code does not make any sense.
BehrouzHosseini
Thanks Rober,
it was a Typo there but what I am trying to do is Adding a Point into Map using Toolbar facility and also Drawing a Circle around it without using Toolbar Utility
Bengi,
   Why are you trying to use the Draw toolbar and not just adding a map click event handler when the button is clicked and then in the handler add the circle as in this sample?
Create circles | ArcGIS API for JavaScript 3.22
BehrouzHosseini
You are right but in this case I need to also display the Point Graphic on map so as you can see I have two graphics layer
Bengi,
   There will be no problem doing that if you create two different graphics (as a graphic can only exist in one parent layer at a time).
BehrouzHosseini
Thanks again but please do not forget the
$("#btnAddJunctionFlag").on("click", function () {});
 I am actually calling (enabling) this Point creation functionality on calling a DOM (here # btnAddJunctionFlag) and as you know this is different than
map.on("click", function(evt){})
Here is the code in more details
   geodesic: true,
   radius: .6,
Thanks and sorry for confusion
Bengi,
   That is no problem. As mention in my previous reply you can just add the map on click handler inside the button click handler.
BehrouzHosseini
Sorry Robert I got confused! so you are saying I can add Point to map without using Draw toolbar AND with using
 can you please let me know how?
Bengi,
      geodesic: true,
      radius: .6,
