AnsweredAssumed Answered
Survey 123 and Collector - Portal
Question asked by cgoessl on Oct 23, 2017
Latest reply on Oct 24, 2017 by JTedrick-esristaff
I have been able to create a Survey123 that links to portal. I have gotten to the point that when I click the link to add inspection within Collector, it will open Survey123 and open the survey.
Back end information:
I have created a table that relates to the feature class.
  • Cardinality: 1-M
  • Name: GatewaySign
  • Primary Key: GlobalID
  • Foreign Key: ParentID
  • Destination Table Name: GatewaySignInspection
Within the xlsForm I added the following row:
  • type: text   (will switch to hidden once I get this to work)
  • name: ParentID
  • label: Parent ID
  • bind::esri:fieldType : esriFireldTypeGUID
In the collector map, configure pop up,  I have created the hyperlink to open the survey123:
  • arcgis-survey123://?itemid=427517a8e0fb49138bedba1e64d0adde&field:ParentID={GlobalID}
The issue I am getting is the survey data will not return to the collector data. Here is the error I am getting:
SEVEREOct 23, 2017, 2:53:13 PMAn error occurred.Collector/CollectorGatewaySigns.MapServer
SEVEREOct 23, 2017, 2:53:13 PMEdit for the Feature in Layer: 1 is not applied.Collector/CollectorGatewaySigns.MapServer
SEVEREOct 23, 2017, 2:53:13 PMError: A general error when something is wrong with a Field. [ParentID].Collector/CollectorGatewaySigns.MapServer
Thoughts
Outcomes
