AnsweredAssumed Answered
Two shortlist questions
Question asked by Wildlife_Friendly on Oct 23, 2017
Latest reply on Oct 25, 2017 by Wildlife_Friendly
Hi! Two quick shortlist questions:
1. What is the easiest way to use an embedded video in place of a large photo? I assume something needs to be tweaked in the javascript to allow this functionality. Any suggestions would be greatly appreciated.
2. What is the easiest way to add a search filter/query to filter the points by a categories defined in a .csv? I've seen a bunch of examples of the searchbox "widget" that can be embedded into the map code, like this one: Search widget with multiple sources | ArcGIS API for JavaScript 4.5  just not sure where this (or similar) code goes.
I'm doing everything via csv and hosting on my own server. I also have some basic familiarity with js and html so just need to be pointed in the right direction! Thank you so much!
Outcomes
