AnsweredAssumed Answered
Unable to create replica. unable to download Map
Question asked by jmaustin_3 on Oct 23, 2017
Latest reply on Oct 24, 2017 by jmaustin_3
I have been trying to download a map with Points, Lines, Polygons and raster's to be used offline from ArcGIS online through the ArcCollector app. I keep receiving the same error. It will download depending on the scale either 20% or 80% then I will receive the classic error message of [Map Download] Unable to create replica. Please check your parameters. Exporting data from layer 1 failed.
Here are my unsuccessful troubleshooting Technics:
1. Checked settings for hosted feature layer (Offline Use)
2. Check Map settings to make sure Offline mode is enabled.
3. Removed Layer 1 in contents panel.
4. Removed potential data that could be the same (Stream_Line and Correct_Stream_Line)
5. Published/Overwrite existing service
7. Created a new map added feature service.
6.Removed all layers accepted Cached Raster (This obviously worked)
I have concluded its a problem with the Feature Service.... I am out of ideas on how to get this map to work. Any thoughts or answers would be much appreciated.
The map also has SSURGO soils data which could also be a potential problem due to the amount of records.
Outcomes
