Can I edit a table that has been created through responses to a "Survey 123". I see that I can download and then edit the table.
292
10-24-2017 08:48 AM
by Anonymous User
Not applicable
I want to delete some test answers to the survey that I have created but have not found a tool to edit the data or table. short of starting a new survey, how do I get rid of response as they are read and responded to?
CarmelConnolly
Hi Paul,
You can edit the data through the map viewer.
Log into Survey123 (http://survey123.arcgis.com/) > Open the survey in question > Data > Click 'Open in Map Viewer'> Edit > Click on a point on the map you want to delete and the Delete button will be in the pop up.
If this doesn't work for you, log into www.arcgis.com > Content > find the data and add it to a new map > Edit > Click on a point on the map you want to delete and the Delete button will be in the pop up.
Hope that helps!
Carmel
