Hello, I downloaded the story map template from GitHub. Is there a way to disable the login prompt. I want my organization to be able to view the story map but not have to create a AGOL account. The template is located on my server. Any help is appreciated!!
Hi James
So in this case, the Story Map hosted in ArcGIS Online isn't/won't be shared publicly right? (If it is shared publicly, your users wouldn't need an ArcGIS Online account to view your story via your customized code).
Rupert
Rupert,
I have developed a web application where the user needs to see the story map. I have downloaded the story map from GitHub and placed the code on my server. I cannot share it publicly. The user will not have a AGOL account. The user only accesses the story map through the web application I have created. I need to overwrite the login proxy to story map. I have read developers editing the config.JS file and index.html file by creating a proxy. Thanks
