AnsweredAssumed Answered
Problem with Swipe Tool on ArcGIS Online
Question asked by jsorensen_mlib on Oct 17, 2017
Latest reply on Oct 20, 2017 by KGerrow-esristaff
In previous maps I have developed using ArcGIS Online, I have uploaded a KMZ raster of a historic satellite image to an external server and loaded it into a ArcGIS Online web map using the web URL. From there, I would set up the swipe tool to function with that KMZ raster layer. This has worked terrific until today when I noticed that the swipe tool is no longer working on these layers.
Nothing has changed to the set up that was previously working, so I am led to believe there is a problem with the swipe tool on ArcGIS Online.
An example of one of these maps is found at: ArcGIS Web Application As you can see, the raster layer appears all of the time now, rather than only appearing through the swipe, or in this case, the spyglass.
Is anyone else experiencing a similar problem? Is there a way to contact ESRI directly to report the issue?
Thanks!
Outcomes
