3D volume
553
10-17-2017 05:11 PM
WinnieLau
New Contributor III
I have a lake with some low area (black circle).  We want to build a dam that is 1m thick and 1m tall along that area to make the lake a reservoir.
The base height is 1514m.
We want to know the volume of the dam so we can calculate the material volume.
I created a dam block (1m tall x 1m thick) and aligned it with the lake TIN.  Then tried cut  / fill  it didn’t work.  I tried to make the input area (the dam) extent same as the lake extent but failed.
Is there any other options to find out the volume?
Thanks everyone for your input!
Tags (1)
DanPatterson_Retired
failed as in errors? or failed in as not what was expected? in either case, can you elaborate
