AnsweredAssumed Answered
How to let Labels Placement adjust by whether the polygon is totally inside the map or not ?
Question asked by d93810110 on Oct 16, 2017
I’m using Arcmap version 10.3.1. Recently I need to export hundreds of map by Data Driven Page Setup toolbox. Here‘s the problem I met. I have to make all the maps like picture a. If the polygon is totally inside the map, then it’s label should be set in the middle of the polygon, for example polygon A and B. But if the polygon isn’t totally inside the map, then it’s label should be set outside the map like polygon C-G. And the labels on both sides should be counterclockwise rotate 90 degrees.
Does anyone know how to make the labels automatically like this by Data Driven Page Setup or Labeling or any other toolbox?
                                 picture a
Outcomes
