I have simple drone images (around 1000) from an agriculture area. After the Adjust I ran an Orthomosaic but the result not meet with my requirements. I had an orthomosaic with a lot of wrong mosaics, see attached. First I thought the wrong mosacing occours because of the seamline settings. I set up a lot of different parameters in the Seamline Settings, I trired with a lot of different Computation Method but the errors were still the same. Someone has any experience about the problem?
(On the attached images the blue lines are seamlines.)
László
Hi Lazlo - were you at Portsmouth Uni MSc? I am trying to do a similar thing.
Mark Wilson
