AnsweredAssumed Answered
Field Calculation
Question asked by psawyer_0324 on Oct 17, 2017
Latest reply on Oct 17, 2017 by jborgion
I have a field name in my water line data named " Diameter"  the field is set as a text field string.  I am trying to do a field calculation to add  6" diameter.  I have tried several variations; "6" "" , "6" &""  "6 +"" . I am using the parser vb script.  None of these codes work. I have no problem when I enter in "6" in the field calculation to add the number 6 to set as the diameter. The problem is able to add in the inches symbol ". Should i use the parser python instead of vb script? if so do i select the field as a number or string?
Outcomes
