AnsweredAssumed Answered
Query distinct fail on 10.5 with field longer than 22 char
Question asked by francisgagne on Oct 13, 2017
Latest reply on Feb 14, 2020 by vangelo-esristaff
I'm trying to get the domain of value for a field with 23 characters and it fails.
Here is the query I'm doing on 10.5:
queryf=json
&where=1=1
&returnGeometry=false
&spatialRel=esriSpatialRelIntersects
&outFields=UTILISATEURMODIFICATION
&returnDistinctValues=true
&orderByFields=UTILISATEURMODIFICATION
It returns
{"error":{"code":400,"message":"Failed to execute query.","details":[]}}
When I remove the returnDistinctValues, it works fine but I get every records.
I tried the same exact query on 10.3 with the same MXD and data and the returnDistinct works fine.
Here is the log from the server:
Geodatabase error: Attribute column not found [42S22:[Microsoft][SQL Server Native Client 11.0][SQL Server]Invalid column name 'UTILISATEURMODIFICATIO'.] .
It seems the last characters are truncated. I have the same problem with other fields:
Geodatabase error: Attribute column not found [42S22:[Microsoft][SQL Server Native Client 11.0][SQL Server]Invalid column name 'INDICATEURPROTECTIONGE'.]
Outcomes
