minerjoe
Failed to create replica. Editor tracking fields must be visible
Discussion created by minerjoe on Oct 13, 2017
We are trying to reduce the size of replicas.  One way we could do this is to remove editor tracking fields on the replicas that will not be edited in the field.  However, even if you turn off all edit functionality on a feature service and just leave Sync when you try to create a replica you get the above error
Seems if there is no editing on the Feature Service that I should be able to generate the replica without these fields.  In a large dataset this has a noticeable impact on size
Outcomes
