Invalid file geodatabase release.
3209
10-12-2017 12:43 PM
MaiaPeck
After I used ArcGIS pro to open a file geodatabase that I created in ArcGIS 10.2.2 ( ! ) I can no longer open it in either version, and I get the message:Failed to connect to database. This release of the geodatabase is either invalid or out of data. [Invalid geodatabase release]
Is there something I can do to be able to open this geodatabase in either version?
Thanks. Lots of work in that geodatabase....
JamesMacKay3
Hi Maia, have you tried this tool?
http://resources.arcgis.com/en/help/main/10.2/#/Recover_File_Geodatabase/00170000017p000000/
I would make a copy of your File GDB and test it against the copy, it looks like there could be some limitations: "The Recover File Geodatabase tool can only recover simple feature classes and tables. Complex data and relationships will not be recovered."
MarinProdan
great work, thx. This worked for me
