I have an existing feature service that is a polygon layer. I used this feature service to create a survey in Survey123. Everything works correctly UNTIL I go to send the survey data from the outbox, and I get a Send Error. Code 1500 Incorrect Geometry type.
What does this mean and how can I fix it? I am assuming it is due to the fact that my parcel data came into the XLSForm with a field "geoshape" instead of "geopoint." I tried changing to geopoint (did not work), tried making the whole field hidden (that didn't work), and tried making the input hidden (appearance ->hide-input) (that didn't work either).
Sara G.
Hi Sara
The issue is that Survey123 currently does not support polygon feature services - so you can't submit. You would need to create a new feature service based on a point version of your polygons (maybe use the centroid). We do have an enhancement request open for support for polygon features and will add you to it.
John
