I've run into an interesting quirk in my code and I'm trying to track down the source of it. In my application I have about 40 layers, any combination of which can be displayed at one time as 3d polylines. What I want to do is implement a legend widget by adding all of the layers to a group layer, and then using that group layer as the basis for my legend widget.
Here's my function to accomplish that:
function createLegend() {
var legend = new Legend({
view: view,
layerInfos: [{
layer: new GroupLayer({
layers: map.allLayers;
title: "Layer Legend"
});// Add widget to the bottom left corner of the view
view.ui.add(legend, "bottom-left");
The interesting thing is this: as soon as I call map.allLayers, all of the layers disappear from the map. I have a layer list in the app, and it goes from full to empty instantaneously once the call is made. I even set a time delay on the function call: all of the layers remain in the map until map.allLayers gets called.
I put in a console.log( map ) statement before and after map.allLayers gets called, and sure enough the layers are there before the call, and gone after.
I'm wondering if anyone else has faced this kind of thing, and what I might do about it.
Off the top of my head, you might try using map.layers as opposed to map.allLayers. The main difference between those two is that map.allLayers includes the basemap layers.
In general though, it's not obvious to me that your method would work. You aren't adding the group layer to the map, and the legend widget only shows up for layers that are in the current view. Also, I'm not sure if the legend widget can handle group layers at all.
I think, unfortunately, you might just be stuck having a legend that with layers infos that look like this:
