How to compare the same layer in 2 geodatabases
436
10-03-2017 02:04 PM
JoseSanchez
Occasional Contributor III
Hello everyone,
I have the same layer in 2 different geodatabases and both layers have a different number of records.
I am looking for a way to compare both feature classes and find the records that are different between them to siolate them and add them to the one that has less records.
How can I do that?
JoseSanchez
BruceHarold
Jose, Data Interoperability extension has a ChangeDetector transformer that will find unchanged, added and deleted features, or alternatively an UpdateDetector transofmer that will find unchanged added, deleted and updated records.  UpdateDetector requires a shared primary key.
JoshuaBixby
MVP Esteemed Contributor
Have you looked over the Data Comparison toolset
AbdullahAnter
Also you Can try Using Select By Location—Help | ArcGIS Desktop  using method Are identical to , then switch selection to get the different  records.
Note: make the target layer  in selection the layer that have records more than the other
