NIFIGA
[RESOLVED] GDB in Oracle: Error calling SDE.St_GeomFromWKB from OCI
Discussion created by NIFIGA on Oct 3, 2017
Latest reply on Jan 18, 2018 by NIFIGA
-- The anonymous sql-block with St_GeomFromWKB is working good
DECLARE
    :GEOM BLOB;
BEGIN
:GEOM := HEXTORAW('010200000004000000b6f3fdd497961341c74b37097b2042418941606596961341819543bb822042416f1283c05f971341ac1c5a149d20424175931884829613410ad7a350b6204241');
UPDATE "SDE"."MYTABLE" SET "SHAPE" = SDE.ST_GeomFromWKB(:GEOM, 3405)
WHERE "OBJECTID" = 1;
END;
SELECT SDE.St_AsText(SHAPE) AS SHAPE FROM "SDE"."MYTABLE" WHERE "OBJECTID" = 1
This SQL is executed in Oracle SQL Developer with good result.
When my application called this function I'm got the error (using OCI):
ORA-03001: unimplemented feature
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 237
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 162
The BLOB value which application send as WKB is properly.
I'm check it several methods:
- used it as parameter for constructor of SDO_GEOMETRY;
- add the blob field to the table and save BLOB in this field, then convert this value to St_Geometry.
The convertion from BLOB field with WKB value to the St_Geometry also propertly works in Oracle SQL Developer only.
UPDATE "SDE"."MYTABLE" SET "SHAPE" = SDE.ST_GeomFromWKB("SHAPE_BLOB", 3405) WHERE "OBJECT"=1;
The execution this command from my external application using OCI is finished with such error:
The message
is meaning that error while call the funlction geomfromshape() from library "st_shapelib.dll"
Some others functions from "st_shapelib.dll" are successful calling from my application using OCI.
For example the function SDE.ST_AsBinary which calling from OCI application is works properly.
Why SDE.St_GeomFromWKB not working when its calling from OCI application?
Thanks for any ideas!
PS. Additional information.
Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
The library st_shapelib.dll is added to Oracle Database propertly.
SELECT * FROM USER_LIBRARIES;
return
ST_SHAPELIB | c:\app\panuser\product\11.2.0\dbhome_1\BIN\st_shapelib.dll | Y | VALID
Checking "invalid" objects
select object_name, object_type from user_objects where status = 'INVALID'
returns no records.
Outcomes
