I've published a survey using the latest Survey 123 Connect (2.4) to Portal for ArcGIS 10.4.1 . It has an image attachment option. If I include the image , it fails to submit with this error:
Code 500 Tables names should follow the patter <catalog.>schema.table
(see attached picture)
If I remove the picture attachment, the survey submits just fine. This goes to show that the survey is working fine. It just fails on picture attachment.
If I publish a simple survey with just a text field and a photo attachment field , it works. The issue is just with the survey in question.
Has anyone experienced the same error and know what the resolution is?
This works when the survey is published it to Portal for ArcGIS 10.5.1 but upgrading is not an option for now.
Hi Disha - can you confirm the exact version of Survey123 you are on? We have released a patch and are currently on Survey123 2.4.72, Survey123Connect 2.4.60. If you are still having issues with this version please share your survey xls with me.
John
