LoadingShelter question
1826
9
09-29-2017 08:41 AM
KenBuja
MVP Esteemed Contributor
I've having some difficulty with the LoadingShelter when I'm adding that into the Widget.html file. I have put it in there as
<div>
  <div>
    widget content
  </div>
  <div data-dojo-type="jimu/dijit/LoadingShelter" data-dojo-attach-point="shelter" data-dojo-props="hidden:true" style="overflow:hidden;"></div>
</div>
However, when I attempt to show or hide it with
this.shelter.show();
I get the error "TypeError: this.shelter.show is not a function".
If I look at examine it in another widget, say the eSearch widget, its properties are
When I examine it in my widget, its properties are
What am I getting wrong about the implementation?
I have also tried adding the LoadingShelter in Widget.js programmatically in the postCreate function
    this.shelter = new LoadingShelter({
      hidden: true
    this.shelter.placeAt(this.domNode);
    this.shelter.startup();
When I examine it in Developer Tools, its properties are similar to the eSearch version, but I never actually see it show up on my widget
RobertScheitlin__GISP
Ken,
  You are missing the _WidgetsInTemplateMixin from your widget declare array.
Line 2 of your Widget.js:
return declare([BaseWidget], {
//Should be
return declare([BaseWidget, _WidgetsInTemplateMixin], {
Ken,
  Do you have the require for 'dijit/_WidgetsInTemplateMixin', in your Widget.js and
in your Widget.js?
KenBuja
Yes, both of those are in there. If I put the this.shelter.show(); in the postCreate, it does show up.
  postCreate() {
    this.inherited(arguments);
    //LoadingShelter
      hidden: true
KenBuja
Actually, I was hiding it too soon, before the heavy lifting in the function. So when it's added programmatically, it works fine. But why won't it work when using the attach point in the html file?
Ken,
   Before you added it programattically did you have the require for "jimu/dijit/LoadingShelter"? The fact that the this.shelter is complaining it does not have a show method tells me that the div is not actually getting assigned a the LoadingShelter dijit. Which normally happen when the dijit is not imported (required) properly or the widget does not have the _WidgetsInTemplateMixin.
KenBuja
Yes, the 'jimu/dijit/LoadingShelter' module has been in the require since the beginning.
I'm not sure what to tell you. You want me to look over the full Widget.js and Widget.html for you?
KenBuja
That would be kind of you.
Ken,
//Should be
KenBuja
Thanks, Robert, that was it.
